Read the manual.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/882237-140-cooler-master-help/#findComment-10902804
2 minutes ago, PawkyPenguin said:
I have otherwise I would not have asked
It should say. Long story short, use the Intel bracket, put it on/over the CPU block, and attach it to the motherboard using the included screws. Seriously, it should be in the manual.
SPECS:
https://linustechtips.com/topic/882237-140-cooler-master-help/#findComment-10902817
OK, did that but It feels really loose
https://linustechtips.com/topic/882237-140-cooler-master-help/#findComment-10902826
Read. The. Manual. It HAS to be in there somewhere!
SPECS:
https://linustechtips.com/topic/882237-140-cooler-master-help/#findComment-10902833
HAVE YOU SCREWED IT IN YET
if you have it's fine
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/882237-140-cooler-master-help/#findComment-10902849
Yes I screwed it in the metal thing on the back of the motherboard is not solid and I don't know why.
Did you screw the cooler through the holes in the motherboard into the back plate?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/882237-140-cooler-master-help/#findComment-10902885
26 minutes ago, PawkyPenguin said:
I have a LGA 1151 motherboard trying to install a 140 Cooler Master liquid cooler, and was wondering how to install onto my i5 7600k. I'm stuck.
Thanks to whomever responds.
I don' know specifically for the CM. but sometimes these back plates are meant to be loose and tighten down when the block is screwed onto it this was the case with the corsair h100i v2
 If the CM is also an Asetek design, perhaps it' a similar story.
https://linustechtips.com/topic/882237-140-cooler-master-help/#findComment-10902899
