Hi, I'm having trouble getting my new Ryzen 5 system to be stable at higher memory clocks.
Specs:
CPU: Ryzen 5 1600 @ Stock
MOBO: ASUS Prime B350 Plus
RAM: G.Skill Trident Z RGB 16GB (2x8GB) 3200MHz (F4-3200C16-16GTZR)
I've managed to get it stable at 2666MHz and I've run a LinX and Prime95 Stress Test but haven't tried gaming yet. I would really like to get up to 2800+ MHz so any insight would be greatly appreciated. In case you hadn't guessed, I'm new to memory overclocking.
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/881972-ryzen-5-stability-issues/
Well that is gonna be hard, especially on ryzen. Did you also adjust the timings and voltages?
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
Have you tried loading the XMP profile?
Motherboard: Asus Crosshair VI Extreme | RAM: 16GB Trident Z RGB @ 3244Mhz CL13 | Case: Phantom 820 | Storage: 250GB Samsung 960 EVO & 10TB various mechanicals  | PSU: Corsair RM1000 Platinum | CPU: R7 1700 @ 3.8Ghz | GPU: MSI RX 480 Gaming X 8G w/ 580 BIOS @ 1515/2200 | Keyboard: Logitech G910 | Mouse: Razer Mamba (new style) | Sound: Asus Xonar D2X & Nuance Spacial 3 towers | OS: Windows 10 Pro | Display: Acer T232HL | Cooling: custom loop w/ 360mm Rad & Wraith Spire
HWBOT RX 580 3dmark Firestrike Submission
I've tried the voltage but I have never done anything with timings so don't know what way to adjust them or how much.
Yeah it just refused to boot and bumped the RAM down to 2133 in safe mode
Just now, InertiaSelling said:
Have you increased the voltage?
Yeah to no effect. Still either hung system or BSOD
Just now, Thermosman said:
intended timing are 16-18-18-38
set voltage to 1.35v
set speed to 3200
I did that. Just failed to boot
its not gonna be easy to get it to speed. You are going to have to play around with the settings a lot to get it to work, play around with the other voltages
Which voltages should i adjust?
Personnally for my corsair vengance lpx 3000 i have vram 1.4v and cldo_vddp at 1.2v. Also, bump the vcore to 1.35
I'll give that a shot. I know my DRAM Voltage is lower than that. Thanks
16 hours ago, stefanDB said:
have you updated your BIOS?
Yeah downloaded and installed the latest release from ASUS
Try the ram's rated timings and voltage but change frequency to something like 2933. You could also try bumping up Soc voltage.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Thanks. I'll give it a shot.
I just realised I hadn't updated to the latest version on Windows and was using one from 2015 (USB Installer from first build). Gonna do an update and see if that helps.
The SoC tip is a good idea.  I will also say that my board has excellent memory compatibility and one thing I noticed is that it has load line calibration for dram enabled out of the box.  If you have that option for dram I'd give the first level or 2 a try.  The other thing you could look into is vboot.  It can help with the initial booting of the RAM.  Do some research though as I'm not sure offhand how to use this setting (or if your board even has it).  But I've read in some forums of people having success with this.
The Asus Prime B350-Plus already bumps the SOC voltage to 1.1v automatically when it detects memory overclocking (I believe the threshold is going past 2666 MHz for this to happen, but I could be wrong.)
You could bump it to 1.2v, but I wouldn't go beyond that. I had issues with memory compatibility and nothing I did fixed it, from changing voltages, manually setting timings, loosening timings, messing with command rate, adjusting ProcODT, etc. You might end up in the same boat, OP. Welcome to Ryzen.
Current Build:
CPU: Ryzen 7 5800X3D
GPU: RTX 3080 Ti FE
RAM: 32GB G.Skill Trident Z CL16 3200 MHz
Mobo: Asus Tuf X570 Plus Wifi
CPU Cooler: NZXT Kraken X53
PSU: EVGA G6 Supernova 850
Case: NZXT S340 Elite
Current Laptop:
Model: Asus ROG Zephyrus G14
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
CPU: Intel i7 8700K @4.9 GHz/1.315v
Mobo: Asus Prime Z370-A
Yeah it can depend on what individual processor you got, the ram, and the motherboard.  I think I was probably lucky myself but then again I do have a premium x370 board.
Specs:
Sadly you are stuck to what your motherboard can support for the specific RAM sticks.
Ryzen memory support is pretty locked to the motherboard as the motherboard tends to compensate for the memory controller on Ryzen a bit.
I would make sure your BIOS is up to date and check the QVL for your motherboard to make sure the RAM is supported and at what speed it is supported at.
You can get lucky, but with Ryzen, if you want fast RAM speeds, you really need to research what RAM you are buying at the support for your motherboard at your desired speed.
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Specs:
You may not be able to boot at 3200MHz with that ram because I believe the CAS 16 version of that ram (which is what you have) is Hynix ram.  Hynix ram usually DOES NOT BOOT stably with Ryzen at 3200MHz.  The highest I have seen hynix ram go is 2966MHz, even though it says it can go 3200MHz.  You need to find Samsung B-die ram such as G.Skill Flare X or faster Trident Z ram.
My RAM uses Hynix dies and is dual rank 3200 memory (F4-3200C16D-8GVKB), and I had it stable at 3066 MHz for months. BIOS version 3401 on the B350-Plus changed that though, and made 3066 unstable, forcing me to 2933 when I was still using Ryzen.
Current Build:
GPU: RTX 3080 Ti FE
Current Laptop:
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
You are correct according to this page.  I didn't even realize that different models of Trident Z weren't Samsung ICs.  Good thing I got the CL14 version.
https://www.reddit.com/r/Amd/comments/62vp2g/clearing_up_any_samsung_bdie_confusion_eg_on/
Yup that explains why you have no problem hitting 3200MHz.
