odd bay for an odd build
Guest
I want to get a reservoir for a 5.25" bay in a sleeper build in an old case with a lot of 5.25 bays. Any suggestions?
If you're in southern Washington, a visit to the Free Geek located in Oregon may get you a case that matches the description, but I'd recommend in planning it ahead of time with 'em. If you're in northern Washington, the Free Geek Vancouver would be closer.
Regarding just finding a case - I think it's a shot in the dark unless you're looking at used websites.
I also think that's the type of thing that you won't know about until you stumble upon the one that's just right for you.
Edit: Oh Jesus - I completely misread the topic. I'll be revising this more in a minute.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
Here's a list of some 5.25" reservoirs from Frozen CPU's site. I generally wouldn't recommend buying from them directly, but it's a good place to look through brands and such.
If you want a bay res/pump http://www.performance-pcs.com/new-monsoon-series-two-d5-basic-dual-5-25-reservoir-matte-black.html
That brand has a few with different color hardwear on it,The have a light in it so if you run distilled water or clear coolant you can make it light up any color,And it comes with silver plugs so if you run distilled water and copper blocks you got a free kill coil.For single drive bay http://www.performance-pcs.com/reservoirs/shopby/res-type--single-bay-res/
For dual bay http://www.performance-pcs.com/reservoirs/shopby/res-type--dual-bay-res/?
