Hello.
Today i got all the parts i need for my cpu upgrade from 4790 to 8700.
Got my mobo, ram, cooling and ofc the cpu itself.
Its the first time ever im soing this kind of upgrade and im building it myself because i find it really fun.
My question is, do i need to know anything super important before i start building? Because for example when i switched from an amd card to an nvidia card i didnt know about DDU until a friend told me and saved my ass.
So do i need to install anything special? Do anything special? Or just disassemble my pc and build it again with the new parts?
Thank you!
https://linustechtips.com/topic/881044-first-ever-cpu-upgrade/
Hi =)
first congrats on building your machine =)
So from what you wrote you'll keep your drives, gpu, case and PSU, everything else gets swapped out.
It is usually advised to do a fresh install. Because some times windows can get wonky after a major hardware swap.
In my own experience, I never did that =) just removed all the old drivers before the last shutdown in safe mode, then did the upgrade.
As a little advice, before disassembling, when you keep your drives, download the newest drivers for the new hardware so you already have them at hand when turning the machine on for the first time.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/881044-first-ever-cpu-upgrade/#findComment-10891092
Typically its a good idea to reinstall windows after a motherboard change however as you're going from intel to intel, you may not need to. Just give it a try first and if you don't experience any issues then don't bother reinstalling.
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/881044-first-ever-cpu-upgrade/#findComment-10891093
Yep, just rebuild as usual. If you have Windows 8.1 or Windows 10, the OS will reconfigure itself for the new hardware. Update your drivers once you're back in Windows.
If you upgraded from W7/8 to 10 before, you'll need to buy a new Windows 10 license since it's non-transferrable. Windows 7 won't run on Coffee Lake / is unsupported by Microsoft.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/881044-first-ever-cpu-upgrade/#findComment-10891096
15 minutes ago, Anghammarad said:
Hi =)
Alright, i dont think ill reinstall, but downloading the drivers is a great idea as i dont have a dvd drive, thank you!
But.. Removing the drives on safe mode, how exactly do you do that? Didnt quite understand.. Sorry ?
Thank you :) i think ill keep the windows as it is and see how it goes
Ill download the drivers before i disassemble the pc so i can install them immediately as i dont have a dvd driver. Thank you!
https://linustechtips.com/topic/881044-first-ever-cpu-upgrade/#findComment-10891143
drivers =) not drives.
like @NelizMastr said, as long as you run windows 8.1 or higher, just boot up the new system and feed it the new drivers. all should be well then.
Main System:
https://linustechtips.com/topic/881044-first-ever-cpu-upgrade/#findComment-10891159
Ive fully built the pc and while it is booting, it is booting straight to the bios, in the bios it detects the ssd which has windows installed on it, but it doesnt detect the hdd with all the data and games. Im trying to boot into the ssd without success, it keeps getting me back to the bios. What do i do?
https://linustechtips.com/topic/881044-first-ever-cpu-upgrade/#findComment-10891578
Sounds like the bootloader is on the HDD.
So I imagine you have tried another cable and SATA port on the mainboard already?
Main System:
https://linustechtips.com/topic/881044-first-ever-cpu-upgrade/#findComment-10894517
