Best CPU fan cooler ?
i got a dark rock pro 3 and installed it today, had to chop up my pointless ram head spreaders to get it to fit but tbh, it was well worth it. i was running the stock intel cooler for my 4790k which made my cpu run at about 70-80 ish c but with the dark rock pro 3 its running around 45-55 c (under load) :D
CPU: i7 4790k
GPU: Gigabyte Windforce3 GTX 1080
RAM: 8GB Corsair Vengance 1600MHz (@1333Mhz) + 8GB Balisticx Sport or something 1333MHz
MOBO: MSI Z97 Gaming 5
PSU: 1000W EVGA 1000G 80+ GOLD
Case: Dark Base 700
Cooling: Dark Rock Pro 3 CPU Cooler + Standard Case Fans
Drives: Intel SSD5 180GB (Boot Drive) + Seagate Baracuda 1TB HDD + Seagate Baracuda 4TB HDD
Keyboard: Razer Blackwidow RGB 2013
Mouse: Corsair Harpoon RGB
Speakers: Creative T15 Bluetooth Speakers
Microphone: Samson Meteor Mic
Monitor: AOC G2590VXQ 75Hz + ASUS VS247 + Shitty Generic 1080p 60Hz TV
LED Controller: NZXT HUE+
https://linustechtips.com/topic/877863-best-cpu-fan-cooler/#findComment-10862430
Isn't the dark rock a bit overkill for a non overclocked build ?
https://linustechtips.com/topic/877863-best-cpu-fan-cooler/#findComment-10862439
fuck it, cant argue with max 55c on air at 4.2~4.4GHz lol
might overclock it to 4.5~4.6GHz
CPU: i7 4790k
Case: Dark Base 700
https://linustechtips.com/topic/877863-best-cpu-fan-cooler/#findComment-10862442
I got a BeQuiet! Shadow Rock 2, works amazing for the cheap price!
Record holder for Firestrike, Firestrike Extreme and Firestrike Ultra for his hardware
Top 67 for TimeSpy and Top 26 for Timespy Extreme
Intel i7 10700 || 64GB Kingston Predator RGB || Asus H470i Strix || MSI RX 6700XT Merc X2 OC || Corsair MP600 500GB ||  WD Blue SN550 1TB || 2TB Samsung QVO || EVGA 550 GM || EK-Classic 115X aRGB CPU block - Corsair XR5 240mm RAD - Alphacool GPU Block - DarkSide 240mm external rad || Lian Li Q58 || 2x Cooler Master ARGB 120MM + 2x Noctua  Redux 1700RPM 120MM  || Terramaster D4-320 HDD enclosure w/ 1x 8TB 256mb cache 7200rpm Ironwolf & 1x 4tb WD Red 256mb cache 7200rpm
https://linustechtips.com/topic/877863-best-cpu-fan-cooler/#findComment-10862473
If you want low noise and cool temps then nah.
https://linustechtips.com/topic/877863-best-cpu-fan-cooler/#findComment-10862482
18 minutes ago, LoGiCalDrm said:
Evo is good enough. You might still want to downvolt or set manual voltages. Those CPUs are rather hot on stock settings.
Yes the EVO has probably the best price to performance ratio but not the best performing or quiet. That there hot has usually todo with that toothpaste that connects the processor die with the IHS. A shame that a 400+ bucks processor comes with that shit instead of Intel spending 20 cent more for some actual cooling paste.
https://linustechtips.com/topic/877863-best-cpu-fan-cooler/#findComment-10864422
That and the fact that Intel has had issues with voltage control since DC. By which I mean CPUs draw a lot more voltage than they actually need.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/877863-best-cpu-fan-cooler/#findComment-10864523
