sup, i got a question
im looking for a good mouse, i want rgb and i want it to be like a smooth design,
should i get the razer diamondback or the logitech g502, i care about performance and aesthetics as i want an rgb setup
any recommendations would be great, thanks!
Im also wondering if the g502 mouse changes from color to color or if it stays one color
https://linustechtips.com/topic/877766-mouse-help/
Hi
I have a Razer Naga .  (old name)
You have RGB,with a program for control of color and the 12 programmable buttons on the side. You can change the button in a sec. you dont even have to open the program there is and icon on the Taskbar with the options
Also you have a cloud account for storing you programmable buttons selection. The storage is very useful if you format your drive.
Expensive but nice, I use the button for gaming, so no more keyboard for basic fonctions.
As I look at the Naga, they have change it. It is now called a Razer Naga Trinity.
https://linustechtips.com/topic/877766-mouse-help/#findComment-10861846
14 minutes ago, Zmax said:
Hi
Thanks, but what if i wanna click one button i might click 3 at once, and i dont play MOBA and MMO games, so no thanks, any more recommendations?
https://linustechtips.com/topic/877766-mouse-help/#findComment-10861887
You want the G203 or G103 as it is called in some countries. It is identical in design and weight to the G pro but half the price.
If your really into a lightweight mouse i suggest the old G100s but thats just me being really sensitive to the weight.
https://linustechtips.com/topic/877766-mouse-help/#findComment-10865897
should i get the steelseries rival 110?
https://linustechtips.com/topic/877766-mouse-help/#findComment-10866131
not to mention the sensor performance is almost identical, check the followings for more readings
http://www.overclock.net/t/1616323/sponsored-logitech-g102-gaming-mouse-review-by-ino
@Quintavious V I'd personally recommend the G102/G203 for it's low price (I got mine for $20), and it's also RGB. though cheap, but performs way above it's price range.
The Rival 110 is also a nice pick and a good improvement from the Rival 100 but it cost more than the G102/G203.
If I were you, I'd go out and test each of the two and see which one fits better. Money wise it's better to buy the G102/G203 and get something else or save the leftover money.
https://linustechtips.com/topic/877766-mouse-help/#findComment-10867935
sorry if there is duplicates i am copying the list from a website
Corsair SCIMITAR RGB MOBA/MMO Gaming Mouse
Logitech G502 Proteus Core Tunable Gaming Mouse
Logitech G303 Daedalus Apex Performance Edition Gaming Mouse
Logitech G600 MMO Laser Gaming Mouse
Logitech G302 Daedalus Prime MOBA Gaming Mouse
Logitech G402 Hyperion Fury FPS Gaming Mouse
Logitech G602 Wireless Gaming Mouse
corsair m65 pro
razer baslik
logitech g403 prodigy
benQ zowie
logitech g402
razer lancehead tournament edition
razer taipan
steel series sensei 310
razer abyssus v2
logitech g303
there is 2nd list i will post
https://linustechtips.com/topic/877766-mouse-help/#findComment-10872069
i can't test them stores only sells them and they are online so i can't test
i don't really care about cost as much as i care about comfort/precision/extra buttons
https://linustechtips.com/topic/877766-mouse-help/#findComment-10872084
i use a palm style grip, is the g102 or g203 the same sensor as the g502?
https://linustechtips.com/topic/877766-mouse-help/#findComment-10877796
  • 2 weeks later...
1 hour ago, iM8Pizza said:
no, but it performs nearly the same with the G Pro, which uses better sensor than the G502
It use MERCURY sensor which perform about the same but the PMW3366 which is on the G502 has more Dpi,higher perfect control and malfunction speed but in real world they feels identical so its basically G Pro with half of the price.
The rival 110 use Truemove1 optical sensor which perform similar to the mercury
Both has ambidextrous design with only 2 side button on the left side.
Since u need a mice for jitterclicking i would recommend something with light button such as the deathadder elite,Logitech G900 or zowie EC1A but they are big and a bit expensive.
If u can tell us your budget,hand sizes and grip style i can come up with something.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
https://linustechtips.com/topic/877766-mouse-help/#findComment-10933199
