Hello everyone,
I upgraded my system a few months ago and I basically replaced everything except the case, storage, disk drives and power supply. Right now my setup is:
- i5 6600K @ 4,6Ghz (with Hyper 212 evo)
- Asus Z170K
- 16GB DDR4 HyperX Fury @ 2133Mhz
- Gigabyte G1 Gaming GTX 1070
- Samsung 960 Evo M.2 250GB
- Seagate FireCuda 7200 RPM SSHD 2TB
- Unbranded 7-port USB 3.0 expansion card
- 2x random disk drive
- CombatPower 750 Watt PSU
- Acer Predator G7200 case
- Philips Gioco 27" ambilight FHD LCD monitor
- generic Medion 24" FHD LCD monitor
- Madcatz MMO7 mouse
- Logitech G15 keyboard
- Logitech Z623 2.1 speakers
- some random USB accessoires, nothing power-hungry
Aside from the strange brand the PSU is getting a bit noisy and I'd like to replace it for a quieter and (semi)modular one. It's around 6 years old now so I figured it's time for a replacement.
I used outervision's website to calculate power draw and if I factor in my CPU overclock I end up with a recommended 541 Watts. However, if I set the overvolt on the GPU to 11% and the core clock to 2000 Mhz (which is what it runs at now) the recommended wattage shoots up to 794 Watts, which is more than I currently have, and it's working perfectly fine. Is the calculator correct here? Do I really need an 800 Watt PSU?
https://linustechtips.com/topic/876239-weird-power-draw-figures/
you need like a nice 550W
Builds:
4 minutes ago, L. Kenter said:
Hello everyone,
- Asus Z170K
the calculators are a crapshoot. 1070's wont pull more than 175W, the CPU wont pull more than 120W, the rest of the MB wont pull more than 50W. i never saw my 6700k system with a 1070 in it (at the wall) power draw exceed 390W. What they are recommending is a PSU with that amount of output for safety reasons. a good PSU will negate those figures.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
3 minutes ago, L. Kenter said:
Hello everyone,
- Asus Z170K
550 Watts is plenty fot that system. For some headroom you might want to grab a 650 Watt unit with gold certification, that will save you some power due to efficiencies at lower loads.
Most power supply calculators grossly overestimate the amount you need. Outervision's calculator for instance defaults to 90% load (which means everything is running at 90%). As a sort of verification to see how accurate they were for estimating power supply needs, I plugged my setup into their system, then ran Crysis 3 and checked power consumption using a Kill-A-Watt. I could not get even to 60% of what they were recommending.
After measuring my systems for the past 4-5 builds, I've pretty much settled on the following:
  • Single high-end GPU with a high-end CPU: 300W minimum, but recommend around 450W-500W
  • Each additional GPU: Add 200W
  • Overclocking: Increasing the clock speed alone results in a linear increase in power. If you touch voltage, it's exponential. But I don't see overclocking say the CPU only adding more than 20-30W. The GPU may add ~30W or so.
So basically for your setup, 500W-600W should be enough as long as it's a decent quality PSU.
