Ryzen 5 stock cooler?
Crunchy Dragon
So I'm looking at getting a Ryzen 5 1400, and I don't have any AM4 compatible coolers or mounting brackets or anything like that and I was wondering how far I can overclock with the stock cooler.
Thanks!
Thanks!
It may be easier to just point you to another thread about this same topic. I just replied to this moments ago.:)
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
Thanks!
check out bitwit's video it can help @bitwit
It's difficult to recommend ANYTHING he does after watching this video.:D
Thanks!
i've read that 3.7-3.8  is the sweet spot for 1600 and 1700s, altho the 1400 does have a different heatsink, should be about the same.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Oh by all means the stock cooler for Ryzen is decent enough for a 3,8ghz solid, what motherboard are you getting though?
Personal Desktop":
Luna, the temporary Desktop:
Thanks!
Even my Ryzen 1700 stock cooler can get my 1700 to 3.7Ghz at 1.225V and run cool and its a quiet cooler.
You will be able to get 90% of your max overclock from the stock cooler even with a 1700 i bet a 1400 since its half the amount of cores can get to 3.8ghz or so. I think the main issue is it comes with a smaller heat-sink compared to the 1500x? At your budget i can't help but try and convince you to get a 1600 over a 1400 as its a better processor overall even for gaming.
Likely to be a Gigabyte AB350-Gaming. I only have an upgrade budget of 200 USD for this, which is why I'm bundling them.
This video is nice and agreeable.
Personal Desktop":
