Pc Side Panel
Go to solution Solved by -rascal-,
According to InWin's website, you have the G7.
https://www.in-win.com/en/gaming-chassis/G7/
It doesn't look like the G7 has an acrylic or glass side panel option, though...
EDIT: Well...like you said, the GT1 shares the same chassis frame; you could possibly get a GT1 side panel, and just swap it in.
So my father built me this computer a while back and i have been upgrading it ever since, i recently got a new desk so i can now have my computer displayed on my desk. because of this i wanted to change the computers side panel from a partially mesh side panel to a acrylic or glass panel. However when i went looking online for the In Win case i have and i couldn't find it and my father no-longer has the receipt saying what model case it is. The closest thing i could find was the In Win Gt1 i know its similar because the internals and back of the case are identical to the Gt1. If anyone knows what model my case is that would be much appreciated also if anyone knows where i could find replacement side panels that would fit the case that would also be awesome.
(I Attached a photo of the front of the case to make finding the model easier)
Thanks
https://linustechtips.com/topic/874186-pc-side-panel/
Case panels are often product specific. If that type of case didn't also have a window option, you won't be able to just pick something "similar" to fit.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/874186-pc-side-panel/#findComment-10830843
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/874186-pc-side-panel/#findComment-10830851
