depends on what framerate your target is.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
2 minutes ago, NumLock21 said:
so stop worrying about bottlenecks.
no no. nonono. The point of worrying about bottlenecks is not trying to eliminate ALL bottlenecks (which is impossible, yet a lot of people think its not) its to avoid any MAJOR bottlenecks based on use-case and budget, and make sure the person is not wasting money on a part that will be hugely bottlenecked elsewhere.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
If it's impossible then it's better off to just stop worrying about it and just buy the best parts within their budget. It's obvious the majority will try to get a GTX 1070 or 1080 along with a Core i5 or Core i7. Now when you're on a tight budget of say less than $600, now it's really time to look for parts the least amount of bottlenecking as possible.
  • i3 8th gen with GTX 1070
  • i5 8th gen with GTX 1060 6GB
It looks ok, though you may want to consider a higher quality psu (TXM gold, focus plus gold, rmx/rmi, and g2/g3 are all good choices)
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
3 hours ago, PlizGivMonej said:
I am planing to build a new gaming pc with the following parts: https://pcpartpicker.com/user/PlzGivMonej/saved/fdQBP6
Will the CPU bottleneck? And if you have some tips to improve my pc please reply! Thanks.
Unless one is considering using a Celeron with a gtx 1080 Ti, this sort of question has no easy answer.
To start with, every system has more than one bottleneck. The whole purpose of the various cache for example, is to reduce bottlenecks within and without a cpu. Simply put, there is no way to avoid bottlenecks. One can only mitigate them.
Part of the problem when looking at cpu/gpu gaming interaction is the pretty wide load variance depending on the title being run. Besides, would you notice a difference between 110 fps and 125 fps or 41 fps and 43 fps?
