Starting to learn Java, tips?
Buhzrk
Hi, I learnt a bit of JavaScript a few years ago. I have forgotten almost everything.
Want to learn code again, any tips on where to start?
I use Windows and Mac.
i7 8700K Overclocked to 5.2 GHZ, Asus 1080 TI ROG STRIX OC EDITION, Asus PRIME Z370-A Motherboard, G.Skill Trident Z 32GB 3200mhz ,
Corsair Nepton H100i v2, ThermalTake ToughPower 750W Gold,
Samsung 950 Pro M.2 NVMe Internal SSD 256GB , Samsung 960 EVO M.2 NVMe Internal SSD 500GB, 3TB Seagate HDD, 4TB HGST HDD, Fractal Design R5 Black w/SidePanel,
ASUS PG279Q 165hz 1440p Monitor, Corsair K65 LUX RGB Keyboard, Logitech G Pro WirelessZowie Camade, Sennheiser HD 6xx, Audiotechnica AT2020 Rode PSA-1
Download Intellij as IDE and I'd say start with the theory about object oriented programming before you start or find a good website with tutorials.
Here is one I found googling xD
GLHF
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
You're lucky. I wish I could forget that. :)
Note that Java is not JavaScript. Both of the answers target Java which is an entirely different language. If you really insist on learning JavaScript again, try to avoid the common mistake of just stacking framework over framework.
Start with something small, like a website that alerts "Hello World" via JavaScript. Then slowly extend your code. :D
Write in C.
Indeed... I think that you should clarify explicitly what it is that you wish to learn: Is it Java or is it JavaScript?
The single biggest problem in communication is the illusion that it has taken place.
  • 4 weeks later...
Personally, i'd highly recommend using video tutorials, as just trying it isn't for everyone, but using Unity with JavaScript is a great way to start learning, try looking up people like DayDev, or someone like that. It's how I learned Js and C# pretty quick.
Damn man, not to attack you but expected something like.
"Don't, learn C or Lisp"
Everyday of 2018 so far managed to surprise me.
Quote or mention me if not feel ignored
