CPU Fan & Heatsink Clearance
Solved by LogicalDrm,
14 hours ago, kb5zue said:Thanks for the reply, I found some information that will help. I found this about the case, should have looked here first.
Clearance CPU Cooler 190mm / 7.48" PSU 200mm / 7.87" Graphics Card 296mm / 11.7" (with 3.5" HDD cage)
412mm / 16.22" (w/o 3.5" HDD cage)
Means that you can fit any air cooler you like. I think tallest ones are 167mm-170mm.
