Monitor stand for triple monitor (1 - 34" and 2 - 29")
CowsGoMoo32
I have looked all around for a triple monitor stand for my three monitors which are
2 - Dell UltraSharp 29 Ultrawide Monitor – U2917W
and a ASUS ROG Swift PG348Q 34-Inch Curved Ultra-Wide in the middle
I have looked all over to find a stand that I could put all 3 on with no luck.
Any help would be greatly appreciated.
i5-3570k l ASRock Z77 Extreme6 LGA1155 I G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 I Samsung Spinpoint F3 1TB 3.5' 7200RPM I Sapphire Radeon 7950 3GB I Cooler Master Storm Enforcer I SeaSonic 620W I Windows 7
6 hours ago, Zmax said:
Hi
This may fit what you are looking for.  Finding a way to fit to a desk, may be hard.
https://shop.ictable.com/collections/esports-1/products/ictable-esports
I have found several arms that could fit your need on Amazon, or Newegg . The only problem i see, is finding one that can fit your monitors
Jeez more money than I thought. I was just thinking maybe I should get 3 separate arms while not an optimal solution as you said not many people are looking for a solution to a to this. Any recommendations for this?
