4K Monitor
RobPlev
Been browsing 4K monitors recently and this seems to be the clear choice at the £250-£350 price range.
Wondering what you guys may think?
Link: https://www.amazon.co.uk/LG-24UD58-Monitor-DisplayPort-Freesync/dp/B01JM4E3UC/ref=sr_1_11?s=computers&ie=UTF8&qid=1512082708&sr=1-11&refinements=p_n_feature_two_browse-bin%3A12128846031
I assume you are using AMD GPU's? in that case, LG make some nice displays so you should be good
Fellow Scouser btw :) No I've got a 1070, g-sync is not a massive selling point for me. But if there is an equally good g-sync monitor for the priced I'd have a gander.
Freesync by it's own is nowhere near enough reason to have an AMD GPU, nowadays triple buffered vsync and FastSync technologies both have render FreeSync no big deal, one can perfectly fit a nVidia GPU on any display just after its other features like resolution, refresh rate, panel quality and so on.
Personal Desktop":
Luna, the temporary Desktop:
AY :D doubt you will find a g sync monitor at a similar price, but it will work fine with a 1070
