Realtek HD Audio manager closing immediately
Ashiella
Go to solution Solved by Ashiella,
---Fixed---
Every time i try to launch Realtek HD audio manager from C:/Program Files/Realtek/Audio/HDA/RtkNGUI64 it just closes immediately after opening, i dont get to see anything, i had to look at task manager to see it even attempt anything. how do I fix this? I tried reinstalling the drivers 5 times.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
Just now, L.Lawliet said:
Have u restart?
Clean install the driver?
Try using 3rd party software to uninstall it cause it will delete almost everything including the registry.
I am using Your uninstaller.
Yep, tried all dat.
Specs v-v
---Fixed---
Specs v-v
