I need help finding a white mechanical keyboard
andrewmp6
I'm looking for a white mechanical keyboard but almost everyone i find are a brand i never heard of.Is there any i should look at,And any i should stay away from?I will be using windows 10 if that matters.Thanks guys for any help i can get.
razer has a mercury white blackwidow keyboard. a bit expensive though and also its razer.
PC: ryzen r7 1700 | Gigabyte GTX 1080 Windforce OC | gskill 16gb ddr4 2666mhz | Asrock AB 350m pro4 mobo | 120gb m.2 ssd, 240gb sata ssd, 2tb 7200rpm hdd | 750W Coolermaster powersupply | Phanteks Eclipse case | monitor: BenQ PD2500Q
