Best Monitor for <£600?
Jamdude
So I've just broken my beloved ASUS PB278Q, it was fantastic apart from slight backlight bleed.  I use it 50/50 for gaming and media consumption and am wondering what monitor to go for next or whether to get a TV.
I feel terrible even considering a TV but with the amount of backlight bleed I see on IPS panels these days I wonder whether it's worth the risk.
Any help would be great, thanks!
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
Res?
TVs aren't exempt from backlight bleed. IPS TVs can have backlight bleed in the same way that IPS monitors can.
Edited by SCGazelle
clarified reply
5 minutes ago, lukemcfc said:
Not a TV or close to your price range (way cheaper) but I use this (http://www.elara.ie/productdetail.aspx?mancode=X2888HS-B2&manufacturer=IIYAMA&gclid=Cj0KCQiAjO_QBRC4ARIsAD2FsXOuNOUHgvu0zaZZgDKDqB63jm29MlTYx1QQVz1Hocz-zKuK_GOovPgaArTYEALw_wcB)........it truely is a great monitor and has 1080p!
Thanks but looking for something to be as good or better than my PB278Q
1 minute ago, CyberFern0 said:
Res?
1440p or higher, don't mind 16:9 or 21:9
Asus PG278QR
4 minutes ago, CyberFern0 said:
Asus PG278QR
You reckon to sacrifice IPS for 165Hz and GSync?   Thoughts on something like the MG279Q?
8 minutes ago, Jamdude said:
You reckon to sacrifice IPS for 165Hz and Gsync?
It's the best for gaming.
