Is this way of cooling ok ?
Is this way of cooling ok ? Does it harm the CPU or watercooler ? EDIT: I have 28°C with this
nzxt-s340-elite-matte-blackred-steeltempered-glass-atx-mid-tower-pc-casing-ca-s340w-b3.png
I wouldn't use the water cooler as intake as it'll heat up the case. Better make it exhaust, if possible.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
3 minutes ago, Callum Stringer said:
why would it harm the cpu or watercooler
oh i didnt see the water cooler um i would use it as a output rather than input, it will only draw warm air into the case
dosent actiually harm much, and its the only place it can go in this case so its fine.
Builds:
Looks fine.
When in doubt, don't think too hard.
Just place your radiators wherever you'd put an equal number of fans and just go for it.
Yeah it's only marginal but as exhaust would generally be better.
Also depends on if it's a 120 or 240 Rad.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
120 mm
