How to connect PC to WIFI ?
pcnoobgril
Hello,
I have an internet connection (100Mb/s) and I need to connect my computer to it. The problem is, that I can't connect it with cabel, because of walls. (There is not any way how to connect it with a cable.) Do you know how to do it, with the best internet speed possible? I heard about some wifi repeaters.. But.. Connect PC to internet is best with a cable, is it right? I just don't know, what to do.
Here is a picture of my flat. Thank you for an answer and sorry for my english.
wired is better, especially if the router is far away or through walls as in your case. to connect your pc to wifi you need your mobo to be capable of wifi or add a pcie wifi card to the pc. Another option for wired is a powerline adapter
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
you can use PowerLine Ethernet, they should work pretty well. Linus even did a video for that i think earlier this week
Hi,
Assuming your computer does not have wifi built in, You have 2 options;
1. Purchase a usb/pcie wifi card to use with the pc
2. Purchase an ethernet powerline adaptor so you can connect your computer via ethernet to the router via the power sockets in your walls.
Laptop: Gigabyte AERO 15X - i7 8750h, gtx 1070, 16gb ddr4, 2TB Samsung NVME
Current Build:NZXT h440, Intel i7 5930k, Corsair H100i, Asus x99 deluxe, 16gb Corsair Vengeance 2666mhz LPX, Evga 1080ti hybrid SLI, Evga supernova 1200w, Lg 34gk950f monitor, 2x Samsung 850 Pro in Raid 0 <p>
Powerline
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
4 minutes ago, pasha786 said:
Hi,
I agree. Most pc's don't have built-in wifi. Make sure you don't get a cheap card too or it will limit the speed of your connection. It's a bit tricky with wifi, but here's a decent card I found a while ago and it was cheap too. https://www.newegg.com/Product/Product.aspx?Item=N82E16833704129
