Hey guys,
I was wondering if these cables (https://www.overclockers.co.uk/corsair-generation-3-sleeved-cable-pro-kit-rmi-rmx-sf-white-ca-22q-cs.html) are compatible with my HX750i, I assume they are as they are compatible with the HX line. Would I be correct in assuming that they are compatible?
https://linustechtips.com/topic/861058-aftermarket-cable-compatibility/
it seems so
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
Seems they're not available anymore from any websites I can find, all listed as end of life.
Only option would be to get custom ones from CableMods or somewhere similar.
Edit - actually Scan have some for sale on their eBay page at £52
http://www.ebay.co.uk/itm/Corsair-Individually-Sleeved-PSU-DC-Cable-Kit-Type-3-Gen-2-for-AXi-AX-HX-R-/362109851537?_trksid=p2385738.m2548.l4275
Wow, IMO you'd have to be nuts to pay £85 for some cables. That's only a little under what it would cost to buy a very decent tier 1 PSU like EVGA G2 650.
But I guess we all have our stuff we'd pay more for, just a matter of priorities and tastes.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Those cables will work just fine.  Type 3 or type 4 doesn't matter for all but the 24 pin.  Just need to make sure you get a Type 3 24-pin.
Google is your friend:  http://www.corsair.com/en-us/landing/psu-cable-compatibility
You can also look at CableMod for cables.
I wouldn't straight up recommend them, theres a few catches :). They are the cheapest pre made cables, and their customer support seems to be amazing (they even pay import duties), but I have not heard particularly nice things about the cables themselves. I have seen a few people complain about the sleeving coming off due to it being crimped into the terminal rather than the slide over and melt method. Not to mention that they use crappy OEM connectors and terminals.
If you want a quick + cheap solution, they are a good choice, but if you have the time to get everything sorted, a DIY approach with Molex connectors and terminals, 16AWG wire and MDPC-X/Telios sleeving will likely net you a better result. Even the cheapo Chinese para cord I used on my cables look pretty damn good. It was my first time, but I was surprised at how quickly I picked up sleeving skills. Bear in mind, it did take me a whole weekend to sort everything out.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
