How do I cap my FPS, and I know MSI afterburner works but is there any really simple software. is this video any good.
I also have ASUS GPU tweak if you can do it on there.
Thanks
Quote
"(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr
https://myanimelist.net/profile/AnalCavity
PCPartPicker URL
https://pcpartpicker.com/b/bsJ8TW
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/
3 minutes ago, AlwaysFSX said:
You enable vsync in the game settings....
then what
Quote
PCPartPicker URL
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/#findComment-10703380
Just now, Max_Settings said:
Then nothing, you are capped.
what am I capped at
Quote
PCPartPicker URL
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/#findComment-10703386
but i want it capped below my refresh rate/I want to customize it
Quote
PCPartPicker URL
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/#findComment-10703390
Thanks
Simple just get a $30 gpu
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/#findComment-10703410
Because the game I play constantly goes between 120 FPS to 8FPS, so it freezes starts freezes starts...... over and over again so I want to cap it at around 60-100FPS. It is not a technical difficulty.
Quote
PCPartPicker URL
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/#findComment-10705429
I have a similar question, I have a 72hz monitor. Does it make sense to cap my fps to 70fps to be able to set higher graphic qualitiy?
I know I might run into frame latency but they seem to be at around 10-20ms, which is OK for me.
I have a freesync Monitor and activated via Radeon Tool.
And another question, which is the best way to cap the fps? AMD Radeon tool, RivaTuner or ingame?
Thanks!
My Setup:
CPU: i7 4790 @3800 MHz, MB: MSI H87-G41, Grafik: Gigabyte GTX 1080TI, RAM: 2x 8GB DDR3 (1600), Storage: Samsung SSD 850 Evo
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/#findComment-10733159
Thanks!
RivaTuner, go to msi after burner and when it gives you the option the install rivatuner, check that box and uncheck the MSI afterburner box.
Quote
PCPartPicker URL
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/#findComment-10736652
Okay. I am surprised. I thought that the AMD Radeon tool would maybe do a better job :D.
thanks
My Setup:
https://linustechtips.com/topic/860270-how-do-i-cap-my-fps/#findComment-10737129
