Need help with CPU upgrade
Solved by Jurrunio,
You can put any 6th and 7th gen CPU on there, even unlocked ones (though you cant overclock).
Your RAM is fine. DDR3 runs at a higher voltage than DDR3L, but many mobo manufacturers use independent memory controllers for DDR3 support anyway so it doesnt matter.
Ernur ·
Posted in Programming0 -
1
VirusDumb ·
Jayraj ·
Posted in Power Supplies1 -
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
8
5
ken43 ·
Posted in Troubleshooting5 -
9
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
