This may be a stupid question.  If a power supply has a AC input from 100v - 240v does that mean the power supply can be used universally?  For example the power supply would be compatible with an american wall socket but also be compatible with a wall socket in the UK.  Please help.  Thanks.
https://linustechtips.com/topic/856993-question-about-power-supply-ac-input/
I have seen some older ones with a switch on them for just that use, but that was a long time ago, I don't think I've seen such recently, but I"m not an expert on that
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
yes
Yes, exactly that it means.
It means that the input voltage can be anything between those two...
"Hell is full of good meanings, but Heaven is full of good works"
