I’m currently saving up for this build.
https://pcpartpicker.com/user/itwasthecontroller/saved/bVhjcf
Im going to use it for gaming and some unity game design. I have one 1080p 60hz monitor right now, but I would like to get a second one later on.
How does it look? Are there any major issues? All feedback appreciated.
https://linustechtips.com/topic/856484-first-build-help/
Looks good but, you might want to look at a board from Asus, I've heard MSI boards for AM4 are quite rather crappy. @dave_k gets tagged a lot because of AM4 boards apparently having a generally poor selection of VRMs on a lot the boards.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/856484-first-build-help/#findComment-10664615
I'd go with an i5 8600 and wait until buget boards arive in begin 2018
https://linustechtips.com/topic/856484-first-build-help/#findComment-10664624
8 minutes ago, Lennart van de Merwe said:
I'd go with an i5 8400 and wait until buget boards arive in begin 2018
Eh, I'd say for a more mixed use case like OPs, I say the R5 1600 is a better chip. Both CPUs will do fine of course.
https://linustechtips.com/topic/856484-first-build-help/#findComment-10664651
Asus doesn’t have many AM4 boards but I’ll take a look at them.
https://linustechtips.com/topic/856484-first-build-help/#findComment-10664653
The motherboard is garbage, it's the worst B350 board.
Get faster RAM. It impacts performance noticeably.
Get the 250GB SL308 for $8 more.
Way overkill wattage on the PSU. 550W is plenty.
The Corsair AF fans are crap. Just use the stock case fans.
https://linustechtips.com/topic/856484-first-build-help/#findComment-10664834
