Can anyone help me?
Go to solution Solved by minibois,
All 1151 CPU's that are not 8th gen:
https://ark.intel.com/Search/FeatureFilter?productType=processors&SocketsSupported=FCLGA1151
So ignore all CPU's that start with 8 (like 8700K, etc.)
Or maybe even easier, all CPU's on its QVL:
https://www.msi.com/Motherboard/support/B250-GAMING-PRO-CARBON#support-cpu
But were you looking for any recommendations? What kind of price were you thinking about? What are you gonna do with it? etc.
Also, keep in mind you will need some DDR4 as well, it might be easiest to just list off everything you have atm.
pentium g4560. i7 7700(k), i5 7600(k), i5 7400
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/855287-can-anyone-help-me/#findComment-10651650
https://linustechtips.com/topic/855287-can-anyone-help-me/#findComment-10651651
You need a Intel Core i series 6th or 7th gen CPU. What CPU are you trying to fit into the socket?
" Supports 7th/6th Gen Intel® Core™ i3/i5/i7 processors, and Intel® Pentium® and Celeron® processors for Socket LGA1151 "
https://www.msi.com/pdf/presale/B250-GAMING-PRO-CARBON
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/855287-can-anyone-help-me/#findComment-10651652
5 minutes ago, Isellping said:
The cpu i have is a intel core i5-4460. The price range i would like if i need to buy a new cpu is up to £100. Thank you for the help so far!
also do you think it will be worth me tsking my motherboard back and buying one that will fit it.
That's a Haswell refresh chip. I have mine on a Z87 motherboard. What you need is an LGA 1150 socket motherboard for your 4460.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/855287-can-anyone-help-me/#findComment-10654445
4000 series CPUs go in H/Z87 or H/Z97 chipsets. "Z" is high tier, has Intel Rapid Storage support and "H" is mid tier. Any motherboard for your current CPU will use DDR3 1600Mhz RAM natively, "Z" chipsets can usually go higher will little to no work. I bring this up because your original post mentioned a DDR4 based motherboard, so I am guessing you have DDR4 RAM on hand right now.
Edited by Gikero
Typo
https://linustechtips.com/topic/855287-can-anyone-help-me/#findComment-10659902
