Hey guys,
I've been out of the tech game for a while because my current rig has served me very well, but I'm thinking it may be a good time for an upgrade soon. I really want a rig that's super small but packs a punch. I had my eyes set on the Silverstone SG10, but I'm starting to think I want to do a custom watercooling loop. Do you guys have any suggestions for a very small case (either matx or itx) that could support a cpu+gpu loop? Possible expansion to 2 gpu's in the loop would be nice as well (obviously not a requirement though since itx would take that out of the question). Ideally, it would have mounting areas for two 240mm radiators or one 360mm radiator... Maybe even a 240mm and 120mm.
I'm just not sure if there's a case out there that fits the bill. I was thinking of the inwin 301, but the airflow in that case looks pretty atrocious. Let me know if you have any suggestions.
https://linustechtips.com/topic/853997-small-case-for-h2o-cooling/
in a small ITX case? No. And to be honest, you dont need that many rads anyways. Two 240mm rads should be plenty. I'd use something like the Define Mini C, not the smallest mATX case but still portable and affordable
I think you misunderstood what I was saying. I'm only looking for space for two 240mm rads OR one 360mm. Not both. Basically I'm just looking for enough surface area to cool a cpu and gpu.
I'm going to definitely take a look at the Define Mini C when I get off work though. I was also looking at the phanteks enthoo matx, but it does seem a little large.
Image result for doh
Thats my bad! Haha. And I wouldnt get the Evolv anything (atx, matx, mitx) because they have TERRIBLE airflow.
Case size
210 x 412 x 413 mm
There's also The Corsair Air 240
Case Diemnsions
12.60" x 10.24" x 15.63"
OK, I think I'm sold on the Define Mini C. It has better overall airflow, I really like that there's a tempered glass version, it's smaller than the Phanteks equivalent, and I'm fairly confident I can jam a 360mm radiator in the front with a little elbow grease, assuming I ever want to run dual graphics cards. It seems to be a very well thought out case, and it's probably about damn time I went with Fractal. My previous builds have all been Cooler Master and NZXT.
Nice! Just be careful about your length of GPU, Most normal Air cards will fit, but some cards like the Strix wont play nicely with the space limitations. If you water cool it, it will fix the issue since the water blocks are smaller.
I havent seen anyone fit a 360 RAD in the case. It's doubtful, but it does officially support three 120,mm fans at the front.... I think the issue will be the RAD top where the tubes have to enter/exit
There was a reddit post I found where someone was able to do it, but they had to use a specific radiator. I'll probably buy the case first so I can make some measurements of my own before deciding on a radiator. If it doesn't work, I can always just grab a 280mm.
Best luck to you, good sir!
11 hours ago, Vortex88 said:
So... What's your opinion of the Define Nano S? Looks like I should be able to fit a couple radiators in there, but I'm thinking I could go with thicker rads in the mini c. I'm not totally sure though.
You might be able to fit two 240mm rads in it, but it will be Incredibly tight. I haven't seen anyone do it yet
