1 minute ago, Grigor said:
Why i have only C can i add more disks ?
you currently only have 1 drive
you can add as many as your motherboard can support (number of sata ports)
you can also split  your drive in more than 1 partition to have it look like 2 drives.
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636068
i dont understand.. so what i should do now to have E or D ?
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636074
buy and plug in an extra hard drive or ssd.
even a usb drive will add an extra location.
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636086
Buy a new drive and install it.
Desktop benching:
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636090
C: is the drive Windows is installed on. Are you asking "I have more hard drives, why are they not seen??", search for disk management, right click the empty hard drive and click "Create new volume" and name it E:, D:, whatever and than your HDD is added in explorer.exe
If you don't have another hard drive installed, this is how it should be.
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636107
i cant right click.. look that image.thumb.png.78c1227e2c0722d2de45e562715234c1.png
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636127
DO NOT ATTEMPT TO MODIFY THOSE PARTITIONS.
Why do you want to have an "D" or "E" drive?
Gaming Desktop: ASRock Phantom Gaming X, R9-3900x, 64GB RAM, 1.5TB SSD
NAS Box: Gigabyte Z97, i5-4690, 32GB RAM, 22TB, 1TB SSD Cache.
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636166
Just now, RandomGuy13 said:
You only have one drive....    because you only have one drive.
If you plug another drive in.....   then you will have another drive.
Don't try and mess with the C drive partitions. Otherwise you will mess up your windows.
so how to fix it ?
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636187
1 minute ago, RandomGuy13 said:
Nothing is broken, You just only have one drive. You have enough space on that drive to put all your programs, and files on it. If you start to fill up that drive and  need more space, then you add another drive.
i mean how to add D; E;
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636200
i dont care E or D just to have one more disk.. not only C
Why? There is zero performance benefit.
Think of your drive like a pizza and your partitions as slices of that pizza. Currently, you have one VERY large slice (essentially the whole pizza) and two VERY small slices (essentially nothing). If you create more partitions, you are slicing your large slice into smaller slices. There is zero benefit.
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636201
so i have only 250gb ? But my HDD is 1TB !
Oh shit, I didn't see the "unnallocated space"
Right click on the black area called "unnallocated space" and click on "new simple volume"
https://linustechtips.com/topic/853895-some-help-guys/#findComment-10636223
