I am planning to upgrade from my current build:
  • I5 4690K @4.2Ghz
  • 1070 FE
  • 16Gb 1600 mhz DDR3(2x8)
  • rm850x psu
  • z97x gaming 3
  • BD-28 (Sharkoon)
I will (hopefully) upgrading to
  • I5-8600K (At around 4.9/5 Ghz)
  • AIO(Need help deciding which one to get as I am a noob)
  • Asus Prime Z370-A
  • Keeping PSU/Storage devices
  • 16Gb 3000 mhz DDR4 trident z rgb
I also need help selecting a case, I am looking at phanteks at the moment. The P400S Tempered glass (Can't find out about airflow, noise etc) and the Pro M(Or SE) Tempered glass.
If anyone can help with choosing an AIO and are able to give some more information about the cases (or if you have suggestions).
TIA
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
https://linustechtips.com/topic/853859-need-help-with-new-build/
https://www.amazon.com/Corsair-Extreme-Performance-Liquid-Cooler/dp/B019EXSSBG/ref=sr_1_2?ie=UTF8&qid=1509549509&sr=8-2&keywords=aio
That's what I would recommend for an AIO. As for the rest of the build it looks good. I also noticed you didn't show your storage devices, as long as you have an ssd as your boot drive your fine. Also great processor choice, It will be hard to find now but trust me when they restock they will be worth the wait.
Former Bronze Contributor
CPU: Intel i7-7700K 4.2 GHz / CPU Cooler: Cryorig H7  / Board: ASRock Z270 Taichi / GPU: Nvidia 1060 6gb EVGA SC / GPU Cooler: NZXT Kraken G12 with Thermaltake Water 3.0 120mm RAM: White Corsair Vengeance LPX 16GB DDR4 2666 MHz SSD: 2x Samsung 850 Evo 250 and 3TB WD blue HDD / PSU: Corasir 550cx / Case: NZXT s340 Elite White
Im a super Italian. Kapish.
  • I5 4690K @4.2Ghz
  • 1070 FE
  • rm850x psu
  • z97x gaming 3
  • BD-28 (Sharkoon)
  • Asus Prime Z370-A
TIA
Get a H110i and you should be good
Yeah, my storage is an old transcend SSD for boot, a 2tb toshiba HDD and a new 120gb Kingston ssd
Than your all set!
@Douglas The Duck Even though I will be doing gaming about 99.99% of the time, if I were to stream, would the 8600k still be decent?
Yeah
Just now, brob said:
@DrBonesMcCoy
Why are you upgrading the cpu?
When playing games like R6 on low, I get insane stuttering, casuing me to have to go on ultra to avoid stuttering and minimise load on CPU. It's annoying as I get less FPS, So upgrading the CPU is one of my only choices
Definitely annoying. Have you read https://steamcommunity.com/sharedfiles/filedetails/?id=739436571?
Don't even need to read that, I have tried everything to reduce stutter. Even gone as far as to get another 4690k just to see if my chip was dying (Stolen from brothers rig hehe). It seems that if I want to play the game smoothly I HAVE to sacrifice a good 30 fps, which means I can't use my 144hz monitor to its full potential.
Can't you just overclock the chip? I have a friend with a 6500 and a 1070, with no issues in Rainbow Six Siege.
He didn't have the necessary cooling requirements
I have a cooler master 212, And if you look at the my forum signature you can see it is over clocked to 4.2Ghz, up from the boost of 3.5, which is what this chip runs at stock. The cooling is sufficent, but even after overclocking all the way upto 4.6Ghz, the I only got a difference of about 5-10 FPS.
I would personally you get two more cores with 8th gen
Exactly why i'm upgrading. A 1070 and a high end i5 can play 1440p no problem. aslong as I reach 144fps+ in most of my games im happy lol
Also, with one of the newer CPU's (8600k) You can easily reach 5Ghz, MUCH higher than previous I5's. I would imagine you can get even higher with a good delid.
Maybe this way I can get One thousand FPS on MineCraft Kappa
@Douglas The Duck could you help me with something to do with RAM really quick?
Sure, whats up
What is the difference between these two sets?
@Douglas The Duck ^^^ Don't think it notified you
Yeah I just got notified, sorry.
The bottom version is the updated version of the kit I believe
Thanks for the help :D
No problem :)
