Need help deciding on what motherboard to get. I can't figure out why these are priced so differently.
TBH if you don't really know the exact feature differences the best option will be the Asus ROG Strix Z270e, as it is pretty much the same as the other two minus some styling and some connectors/headers. Also, the number of monitors you want to run at a certain resolution depends on your GPU, these motherboards will all be the same as far as that goes.
Important features all 3 of these motherboards have:
-m.2 support
-SLI and Crossfire support
-Up to 64GB of DDR4 RAM at every speed between 2133MHz-3866MHz
-Overclocking support
-Raid 0,1,5,10 support
-RGB headers if that's your thing
-Multiple sata ports
-USB type-c
-If you want built-in Wi-Fi the ROG Maximus IX Hero DOES NOT have it, the other 2 do.
Otherwise, the more expensive board will have better rear IO so more USB connectors of all types vs the cheaper one. Same goes for motherboard connectors. You get more 'accessories' on more expensive motherboards like more thermal sensor headers, more fan headers, and more RGB headers. I'm sure the build quality is better on the more expensive board but if it was me I would say get the Asus ROG Strix Z270e. It's a super loaded board and will functionally be just as good as the Maximus IX Formula.
