How much of an upgrade would this be % wise?
Intel Core i-5 3570k @4.2 GHz
Corsair Vengeance DDR3 1600 MHz CL8 16GB (4x4GB)
ASUS P8Z77-V PRO
VS
Intel Core i7-8700K
G.Skill Trident Z 3200MHz CL 14 32GB (4x8GB)
ASUS ROG STRIX Z370-F
Ryzen 9 5900X | Strix x570-F | RAM 32GB @3200MHz CL14 | 1080 TI | Monitor 1440p 165Hz ISP
https://linustechtips.com/topic/851799-system-comparison/
Just now, A_Mediocre_Kangaroo_Farmer said:
In 0.1% fps lows
So for gaming?
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614490
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614493
In 0.1% fps lows
Google it?
Specs v-v
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614497
yes. 1440p 165FPS gaming. I'm looking to avoid dips
I think the GPU is more important, what do you have?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614517
2 minutes ago, Aytex said:
Whats your graphic card..
I would be using a 1080ti
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614525
Then get the CPU.
SPECS:
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614528
Probably a decent sized upgrade, Not sure how less of a bottleneck you would get from playing on 1440p though.
I mean if you have a 1080 ti and can afford the upgrade you might as well.
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614531
no bottle neck even at 165 fps?
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614542
You can't give an exact % it varies for every single game and program. But the 8700K would be a great upgrade and it is the fastest gaming CPU there is at this time.
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614543
It puts less of a load on the cpu because you're playing on 1440p so you utilize more of your graphics card.
If you want to hit 1440p 165hz though, Definitely upgrade.
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614546
Exact % isn't really what I was hoping for anyway. but a guesstimate from someone who feels confident with the cpu and ram comparison would be greatly appriciated
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614551
Just youtube benchmarks? and compare them.
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614556
I've tried to find 1440p high fps comparisons but it's not that easy
Well for that spec you want the most horsepower you can afford so go ahead go for the upgrade,
https://linustechtips.com/topic/851799-system-comparison/#findComment-10614566
