2 minutes ago, Darkdestroyer445 said:
My original RAM works fine but this doesn't at all. Anybody know what's wrong?
Try different slots or something, or another system if you have one.
https://linustechtips.com/topic/851175-help/#findComment-10608038
1 minute ago, Darkdestroyer445 said:
I already have.
Then RMA the RAM most likely
https://linustechtips.com/topic/851175-help/#findComment-10608047
are you only using that one stick? or do you have more than one stick in?
If you want to argue with me, and you probably will please PM me, no need to ruin threads becase you dont like how I am.
Ask me how I made 100k selling illegal narcotics!
and you think im joking, Did a lot of wrong to get my money right.
I look up to Larry Hoover.
Your homies loyal 'til the one time you tell 'em no
https://linustechtips.com/topic/851175-help/#findComment-10608051
Return/Exchange the RAM because it isn't working?
https://linustechtips.com/topic/851175-help/#findComment-10608053
1 hour ago, Darkdestroyer445 said:
Only the one. But when I out another stick in, it still doesn't work.
does the pc boot when  you only use one stick of ram?
the new one
how many GB is the first stick
if the timings are different the RAM wont work together
https://linustechtips.com/topic/851175-help/#findComment-10608073
the new one
It doesnt boot when I use one stick. The old stick is 4gbs and the timings are a lot different. The 4gb stick is 1600 and the 8gb is 1250.
https://linustechtips.com/topic/851175-help/#findComment-10608083
the timings are not the mhz, timings are numbers youll see on the package or sticker it will be numbers separated by a dash like  9-9-9-24
so the 8gb stick does not work on its own then you probably received a dead stick of ram and should RMA it.
its not uncommon for pc parts to arrive dead. electronics aren't perfect
https://linustechtips.com/topic/851175-help/#findComment-10608096
Oh okay. Well thank you.
https://linustechtips.com/topic/851175-help/#findComment-10608106
Even if you mix sticks they'll stick work together usually, it'll just default to the lowest speed.
https://linustechtips.com/topic/851175-help/#findComment-10608107
yes if a stick is 1600 and ones 1866 the 1866 will downclock to 1600. thats common knowledge
but from what i understand and my experience RAM with different timings dont work together
https://linustechtips.com/topic/851175-help/#findComment-10608114
2 minutes ago, Zmax said:
One possibility, that you new ram is not compatible with MB. Did you buy same brand.
DDR3 is DDR3
https://linustechtips.com/topic/851175-help/#findComment-10608175
The ram with the tighter timings would loosen its timings to match the set that has looser timings in the first place.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/851175-help/#findComment-10608189
hmm its never worked in my rig, worked in a buddies with the same timing so i gave it to him but in my rig didnt post, not a dead slot either as all my slots are full now
https://linustechtips.com/topic/851175-help/#findComment-10608281
