I am still deciding on the Meshfiy C and the Crystal 460X (why am I so indecisive)  and they are both perfect in different ways. Since it is an RGB build, the 460x is perfect but I am worried about cable management since in the video linked below he really struggles with cable management and I will have most of the same hardware (commander and lighting node pro and 6 fans) so I will be in a similar situation. He also has to remove his hard drives to make room for the commander pro which is not an option for me so what do you think? The Meshify has amazing cable management but since it is an RGB build, the 460x is more suited (and has more room for an AIO)
(Silly me forgot to add the video)
Edited by A Silver
Forgot to add the video
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/851103-cable-management-in-2-cases/
I like the look of the 460X vs the Meshify C(no offense Fractal Design).
I like the mesh, but the angles kinda ruined it for me.
I love the look of both cases and I keep changing my mind on which one I want. Since I am not the best at cable management I would like it to be as easy as possible which is why I am concerned with the 460x as there is not much room for cable management.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
Go with the Meshify then! Whatever suits you is the best
Your birthday is coming up soon, better decide quick ;)
