So I have 2 250gb SSDs in raid that I have been using to put my more demanding steam games on. I am having the same issue as the guy HERE, the drive does not show in explorer, disk manager says that it is unknown and needs to be initialized. I unplugged and then put everything back which did fix the problem, like the other poster, but it is back again after a day. Any ideas for a more permanent solution?
Windows 10 home 64bit
Processor: i9-9900KF @ 5.0GHz Cooling: Open Loop Graphics Card: RTX 2080Ti Seahawk EK X
Motherboard: Gygabyte Aorus Master Z390 RAM: 4x8GB DDR4 Corsair Vengeance LED 3200MHz
Storage: 6TB all SSDs PSU: Seasonic Focus Plus 850 Platinum Case: Corsair Crystal 570x
https://linustechtips.com/topic/850852-unknown-not-initialized-drive/
Do a backup and nuke the drives, then setup the RAID again and copy all your stuff back. Liking drain¡ve has almost always worked of me.
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
