Ok friends in the tech business and my most favored nerd conglomerate. I live in S. Korea, lots of content is restricted due to region so we need to use a VPN to run Hulu or Sling. I would like to build an HTPC to accommodate the replacement of my xbox one, which will move to my office shortly. The problem I have run into with my research is HTPC overkill, people putting $200 GPU's and core i7's in a $1300 build. My build needs to be able to download and play up to 4k video comfortably, surf the web, watch YouTube... ect. no gaming. Here is what I have as of right now, someone please let me know I am on the right track.
Fractal Design Node 202
Corsair SF450
Ballistix Sport LT 2400 x 8gb
ASRock H270M-ITX/ac LGA 1151
Intel Pentium G4600 Kaby Lake Dual-Core 3.6
CRYORIG C7
Crucial MX300 275GB ssd
Component Total : $540.89
Not sure what to do for the OS, I'd love feedback on that as well.
https://linustechtips.com/topic/850471-unique-htpc-problem/
What about the newest generation / higher end Intel NUCs ? Hits all checkmarks, small, stylish, quiet (especially if you put your own case) ; but will cost a bit more.
https://www.amazon.com/Intel-NUC5i7RYH-Barebone-System-BOXNUC5I7RYH/dp/B00WAS1FX6
EDIT: Actually for example the NUC6CAYH should be enough for 4K, and a lot cheaper (you still need to add storage, RAM and possibly a custom case); but I have no personal experience; I've just considered these NUCs for my own video playback needs. YMMV / do your own research / wait for other comments here ...
As for OS: Depends on your needs. I'd go with some Linux distribution and KODI with a web browser of your choice, but that's just me. If you need to use streaming services which use DRM, I believe Windows or OS X is the only way to go usually for anything >= 1080p. But I have not personal experience with DRM streaming, and things might have changed...
Edited by Wild Penquin
Information about cheaper NUCs
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10600095
thats a decent spec, the C7 is a great cooler if you ask me too. performs better then the Noctua L9I and is still quiet and the BY FAR easiest cooler i have ever installed. id probably throw in a GT 1030 or something in that just to have a GPU for stuff that can be GPU accelerated and to get some actiuall settings for when monitors arent playing nice
Builds:
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10600180
My HTPC plays 4K perfectly
I do actually have a Noctua NH-L9x65 I had spare as well
CPU: Intel - Core i3-7100 3.9GHz Dual-Core Processor  ($106.99 @ SuperBiiz)
Motherboard: Gigabyte - GA-H270N-WIFI Mini ITX LGA1151 Motherboard  ($112.49 @ SuperBiiz)
Memory: Corsair - Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($88.99 @ Newegg)
Storage: Crucial - MX300 275GB M.2-2280 Solid State Drive  ($92.88 @ OutletPC)
Case: Fractal Design - Node 202 HTPC Case  ($59.99 @ Amazon)
Power Supply: Silverstone - 500W 80+ Gold Certified Fully-Modular SFX Power Supply  ($94.99 @ Amazon)
Total: $556.33
Generated by PCPartPicker 2017-10-24 03:38 EDT-0400
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10600226
The GTX1030 doesn't support 4K Netflix, but the Intel HD830 built into the KabyLake i3's does. Really you don't need a discreet GPU.
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10604273
This is something to consider: I wouldn't decode 4K video on the CPU because of thermal issues (which equates more cooling needs and noise). That does not include IGPs which can do HW decoding.
Generally, HW decoding is more efficient (in terms of used W = generated heat). Just make sure whatever you buy has good HW decoding capabilities!
From the above options, I'd go for the KabyLake (and forget a low-end dedicated GPU).
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10617853
New problem/ proposal, I have an Asus laptop that I hate, using it for school while my computer is in transit.  Once my desktop is here and I start my build for the HTPC, I am hoping to use the SSD from my laptop as the boot drive for the HTPC and save myself a fast hundred on purchasing an OS. I have read some forums and the consensus is not clear. Some say it can be done and would work but might violate the Microsoft license, others say it won't work, drivers and such will not play nicely with new components. Any advice?
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10625433
Well, it depends on the license you have for your Windows. Generally, laptops have one-off licenses, so you probably are violating a license in your case. Refer to your Windows license!
Also, it definitely is not a good idea to move a Windows installation to a new computer (motherboard) - especially from a laptop to a HTPC! Reinstall and restore user files and settings afterwards.
That being said, I haven't played with any Windows after and including 7. It may be possible (but unlikely) that newer windowses handle changing a motherboard in a more sensible way.
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10645769
Corsair SF450
CRYORIG C7
Look for a different motherboard. That motherboard does not have a thunderbolt controller onboard, which is required to support UHD @ 60 Hz over the HDMI port for Intel GPUs.
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10665554
i dont know if u r still searching for parts or if u r already finished but i can highly recommend to go with a 7th generation Intel NUC.
i decided to go with them for the following reasons:
  • The 7th generation is able to play 4k media easily
    (i chose the Nuc 7 i5 with the Intel Iris Plus Graphics 640 and 4096x2160 @ 60Hz:
    https://www.intel.com/content/www/us/en/architecture-and-technology/visual-technology/graphics-overview.html )
    With this hardware u r also able to stream 4k Netflix content
  • Connectivity:
    Thunderbolt 3
    HDMI 2.0a (for me thats one of the most important connections bc if u use a TV and not a Monitor u normally only get HDMI)
    DP 1.2
    Usb 3.1
    and so on
  • Upgradeability - u can easily change RAM and the Drives (NVMe / 2,5 Inch HDD/SSD)
  • Formfactor
    I use it in the Livingroom so i dont want a tower or anything like that standing around there
  • Noise
    The System is pretty silent - exactly what i want for a HTPC
  • Flexibility
    I run a full Windows 10 on there - so u can do anything u want with it
To be honest i dont think there is any better choice for an HTPC. Before that i ran a full PC config and it was 'big' and loud. Even a XBOX or PS4 gets way louder than the Nuc. And i dont have any issuses with thermals ( it keeps in the low to mid 60 degrees Celcius)
I got mine now a couple of months and it runs smoothly
No matter if i stream or watch media from HDD.
I just added an external soundcard so i can go with a cinch connector into my amplifier.
And in my Setup it runs with a 50 Inch 4k Samsung TV - no Problems til now.
Cheers
Hans-Linus
https://linustechtips.com/topic/850471-unique-htpc-problem/#findComment-10680673
