Hello All,
I am looking to build a small form factor build for gaming at home in the living room and occasionally taking to work (I work nights so downtime killer).
I have a gaming laptop for work at the moment but it doesn't really get the job done. I will be leaving my job soon hopefully so wont have use for a laptop so the ITX build seems like a good decision as it will fill the gap in my living room where i can use it to game on my TV and use it as a HTPC.
I am looking for suggestions for what to put in it. I am thinking something along the lines of:
CPU: AMD - Ryzen 5 1600
Motherboard: ASRock - AB350 Gaming-ITX/ac Mini ITX AM4 Motherboard
Memory: *G.Skill - Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory
Storage: *SanDisk - X400 512GB 2.5" SSD
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition
Case: Fractal Design - Core 500 Mini ITX
Power Supply: *SeaSonic - G 550W 80+ Gold
Any suggestions for parts or any other ideas would be appreciated
https://linustechtips.com/topic/847998-mini-itx-build-suggestions/
Ryzen typically doesn't do that well with a SFF build. I'd check to make sure the motherboard you've selected has good VRMs...the ones on the Gigabyte board get so hot reviewers have recommended against AIO coolers, and only mild OC with a downward facing fan cooler.
Is the X400 cheaper than the MX300?
I'd wait for Black Friday. You should be able to score some excellent deals.
8 minutes ago, №☢ said:
You don't have to but I would get 4 sticks of ram
How do you figure you'll accomplish that with an mITX motherboard?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
