HBA or Raid Card for jbod
Solved by 8uhbbhu8,
On 10/17/2017 at 3:15 AM, scottyseng said:I would get an HBA card if you're running software RAID.
I would say look up used Dell or HP rebranded LSI HBA cards. I paid $50 for mine. I would also say to get SAS 6Gb/s cards at least (and know you need to buy the needed SAS to SATA breakout cable for your needs).
The LSI SAS2008-8i would work for you.
Well I seem to have found what I need
Thanks for the help Now I just need to wait till I get paid tomorrow so I can buy one
