Can I run a VM on my laptop ? My laptop is on 24x7 and I have a monitor, mouse and keyboard to spare. Plus the audio card on my laptop has two 3.5 mm output ports. I want to replace my mum's lightning damaged desktop but I am short on funds. Is it possible for my mum to have a pc within the afore-mentioned parameters ? Plz help ...
https://linustechtips.com/topic/847259-virtual-machine-for-my-mum/
Running a VM on a laptop wouldn’t matter, it’s the specs that matter. I’d say just give her a separate user account on the laptop. It’d work better than a VM.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
But a separate user account wouldn't allow both of us to use the laptop simultaneously as different users. This aspect is especially important to us as she consumes a lot of Youtube while I do a lot of office work. BTW specs-wise the laptop is way overpowered for office work ...
You can run VM on your laptop, but she would still need to have some other PC, so she can RDP to your VM that you are hosting on your PC.
That's how VMs work.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
But VM's are not office work. You're delegating half of your laptop to the VM and the rest of it to your current OS. You're better off giving her a separate account on your laptop instead of going VM unless you were using a really light version of Linux or something.
"The only thing that matters right now is that you're here, and you're safe."
The two specs needed for reasonable VM work is number of cores/threads and amount of memory. A VM is going to take up a minimum of 2GB of dedicated memory when it is running and at under about 6GB it will be slow. So if you have a laptop with 16GB of memory you will probably be able to run one VM and still get work done on the machine.
The big trick is the most VM software is designed to be accessed either from the console or by a remote connection from another computer, so you need another computer to remote into the VM across the network to access the resources dedicated to the VM. I don't actually know of any off the top of my head that allow a second keyboard/mouse to be attached and dedicated to the VM - but I have generally worked with these in the server or "build a dedicated virtual test system" environments so there may be other tools that I am unaware of.
Found this info, is it any good ...
https://superuser.com/questions/144968/dedicated-mouse-and-keyboard-on-virtualbox-vm
Like I said earlier, my laptop is way overpowered for office work. I am talking 16 gigs RAM, 4th gen i7 3.6Ghz, 8 Gb Nvidia 880M, etc. So I think running atleast 1 VM should be possible.
1 minute ago, CDas said:
Yea, that might work.  It looks like from what the responses say you would need to add a second mouse and keyboard to your laptop, tell windows not to use them, then in the VM configuration - before starting the VM - tell the VM to use the second mouse/keyboard only. I also suspect you are going to have to dedicate the second monitor to the VM, I know in the VM software I have used there was a setting to let me pick windowed or full screen, and if full screen which screen to take over if it was a multi-monitor setup.
Yup I had a similar laptop a couple of years ago and was able to run up to two VMs at a time when doing light file editing in the foreground, one with a software development environment and one with a specific software test environment - both configured with 6GB of memory.
You summarised my requirements perfectly. Now the question is how to do it ?
Unfortunately I haven't actually done this, so all I can say is grab a cheap keyboard/mouse and try it out with a windowed VM before you attach the external monitor.
Basically if you can get your second KB/Mouse to be recognized in the VM and not in windows and your main KB/Mouse to not impact the VM then you are golden. It will be a matter of trying settings and doing google searches :D.
