I am looking for reccomendations for components. I am looking to build a PC for roughly $1000-$1200. This would be used for gaming, streaming, and possibly small content creation. Im looking for a Bang-for-your-buck kinda build. I am also looking to build this around black friday/cyber monday. So any components that may go on sale during these times? This was my current list but I dont wanna spend as much money + I dont think this is very bang for my buck and more of a jumbled MESS:
CPU: Intel - Core i7-6700K 4.0GHz Quad-Core Processor  ($309.99 @ SuperBiiz)
CPU Cooler: Corsair - H115i 104.7 CFM Liquid CPU Cooler  ($139.99 @ Amazon)
Motherboard: Asus - STRIX Z270-E GAMING ATX LGA1151 Motherboard  ($179.99 @ Amazon)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($185.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($98.94 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($66.88 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB D5X Video Card  ($514.98)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($64.99 @ Newegg)
Power Supply: Corsair - CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($78.88 @ OutletPC)
Total: $1640.63
https://linustechtips.com/topic/847170-help-on-build/
I'd recommend a 7700K instead of the 6700K, if you can spare the 20-30 extra dollars. Also, I'd recommend being careful with the TridentZ RGB series as it is known it can become bricked by trying to adjust the LEDs
Frostbite (White build PC)
MSI B350M Mortar Arctic - Ryzen 5 1600 @ 3.9 GHz - Corsair H60 - ASUS GTX 1060 3GB DUAL OC @ (2130 MHz Core Clock + 4600 MHz Mem Clock)
2x8GB 3200MHz Corsair Vengeance C16 Corsair 400C White - EVGA 650 GQ
  Razer Deathadder Chroma - Razer Blackwidow Tournament Edition Chroma - Sennheiser HD 598 SR - LG 24MP59G-P
https://linustechtips.com/topic/847170-help-on-build/#findComment-10563573
What???
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/847170-help-on-build/#findComment-10563576
Just now, Vandorlot said:
What???
There's tons of posts about it. The RGB modification software is extremely dangerous, since it stores the information on the SPD chip of the RAM, which can potentially render it useless by changing stuff it shouldn't.
https://linustechtips.com/topic/847170-help-on-build/#findComment-10563581
It was adjusting the LEDs and using monitoring software at the same time.  It's mostly fixed now
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/847170-help-on-build/#findComment-10563707
27 minutes ago, Alexsolo said:
I just checked and it's more like a 100$ difference...
Buying from the US there's no chance of it being $100 price difference between a 6700k and 7700k.
Unless you were quoting a different part of the post but idk, your response doesn't fit to anything else.
https://linustechtips.com/topic/847170-help-on-build/#findComment-10563723
3 minutes ago, Aidanlockett1 said:
its 400$ and they are like all out
it worth it. he is waiting for black friday, even if he has to pay 400$ the cpu, rest of components should be cheaper to make it up for him otherwise should go for ryzen when think of streaming, content creation & gaming all together.
https://linustechtips.com/topic/847170-help-on-build/#findComment-10563727
if you want to game & stream as well as content creation, dont get anything but 8700k or get ryzen 1700 . it would be terrible decision to buy a 6700k/7700k.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($399.89 @ B&H)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: MSI - Z370 SLI PLUS ATX LGA1151 Motherboard  ($141.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($156.34 @ Newegg Marketplace)
Storage: Hitachi - Deskstar 3TB 3.5" 7200RPM Internal Hard Drive  ($69.99 @ Newegg Marketplace)
Video Card: MSI - GeForce GTX 1080 8GB Video Card  ($509.99 @ Amazon)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Total: $1646.10
Generated by PCPartPicker 2017-10-15 23:34 EDT-0400
https://linustechtips.com/topic/847170-help-on-build/#findComment-10563733
Ryzen for sure if you doing content creation..
PCPartPicker part list: https://pcpartpicker.com/list/3ZBN8K
Price breakdown by merchant: https://pcpartpicker.com/list/3ZBN8K/by_merchant/
CPU: AMD - Ryzen 7 1700X 3.4GHz 8-Core Processor  ($347.69 @ OutletPC)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($123.98 @ Newegg)
Total: $1575.90
Generated by PCPartPicker 2017-10-16 04:26 EDT-0400
https://linustechtips.com/topic/847170-help-on-build/#findComment-10564366
makes sense
https://linustechtips.com/topic/847170-help-on-build/#findComment-10568395
