I know the 9590 runs hot since it has a 220w tdp but taming the heat is not in an issue atleast til i swaped my motherboard, my original board was a msi 990fxa gaming but it cant compleatley handel the 9590's power needs, so i went and bought a new asus sabertooth 990fx r3.0 of which i had seen good things about. But with the asus board my cpu temps skyrocket when doing anything and it ends up doing a thermal shutdown. So far ive tried re seating and re applying new thermal compound (mx4) and adding fans to the vrm and radiator of my h100i aio but to no avail. Just to make shure i was not going crazy i swaped the msi board back in and everything was fine with decent temps even with a stress test running. Please can someone shed some light on this situation
My build
Amd 9590fx black edition
Msi 990fxa gaming (old motherboard)
Asus sabertooth 990fx r3.0 (new mobo)
Corsair h100i aio water cooler
2x gtx 980
32gb corsair vengence
Rosewill quark 1200w psu
Nanoxia ds6 case
And dor the record im happy with what my machine can do, and im not looking to start from scratch, so i ask please dont tell me to get anything differnt processor wise, i will take suggestions on a mobo in the 250 buck range if it comea down to it though
https://linustechtips.com/topic/847157-abnormal-temps-on-9590fx-cpu/
throw it away and buy a Ryzen 3 1200 or a Pentium G4560 on h110m, either will outperform that aberration of tech nature.
Personal Desktop":
Luna, the temporary Desktop:
Check what voltages were running on the  old board, you may have higher voltages in the new one - especially if it doesn't hold steady voltages well. Sometimes the mobo will pump a little higher voltage than what you set, so you'll need to monitor the voltages in real time during the stress test with something like Speedfan.
Just now, lifestinks37 said:
I considerd a zen 7 found a set with mobo for like 450 but im droping cash on 2 titans this check n next
You'll get much better value running a single midrange card and a new cpu. I think even the ryzen 3 will perform better than that FX
2 minutes ago, Colin Donoghue said:
That means new ram and mobo that's like a 360 dollar upgrade
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($109.89 @ OutletPC)
Motherboard: Asus - PRIME B350M-A/CSM Micro ATX AM4 Motherboard  ($69.99 @ Amazon)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($77.99 @ Newegg)
Total: $335.86
Generated by PCPartPicker 2017-10-15 21:48 EDT-0400
A bit cheaper actually, for something that actually works is much well worth it, nobody should be using the 9590 nowadays that processor is bad, hot and one of the most energy consuming ever.
Personal Desktop":
1 minute ago, lifestinks37 said:
Im about to be out of the navy so im trying to future proof this system while i can before i have to start saveing cash big time
Thank you for you service
You know what's sad, there is no American flag emoji on android
Total: $335.86
What about this, i dont mind paying a bit more if it means il be more futureproof
https://www.amazon.com/gp/aw/d/B06W5RRCTP/ref=mp_s_a_1_2?ie=UTF8&qid=1508118774&sr=8-2&pi=AC_SX236_SY340_QL65&keywords=ryzen+7+1700x+bundle&dpPl=1&dpID=51TFKgoj4iL&ref=plSrch
2 minutes ago, lifestinks37 said:
f
All the better just make sure you pair it with decent 3200mhz/3000mhz memory ram, since you only beat the infinity fabric limitation used in Ryzen with your memory running at 2933mhz or higher frequency... then again any thing above 3333mhz does more harm than good due to timings.
Personal Desktop":
Just now, Steven LaFrance said:
go into the bios and set the vcore to 1.4v and restart if you still have this problem put the old MB back in and test it on that MB could be a bad MB and over volting the CPU
Il give it a shot, give me 2 min
