Help to choose best SSD drive
simu
Hi guys/gals,
I want to increase my laptop Compaq Cq57-200UT( https://support.hp.com/us-en/product/compaq-presario-cq57-200-notebook-pc-series/5091489/model/5109482/document/c02842847 & ram 4gb ) /desktop i3 3220 ( motherboard https://www.asus.com/in/Motherboards/H61MK/overview/ and Corsair xms3 8gb ram ) performance.  Both not support SATA III.  Please help me to choose best SSD for my both machines. which really help me boost speed. My budget is 200$ and Are SSD help me to boost my both machines performance?
Please share if other options help to improve my machines performance.
 Thanks!
Buy Samsung.
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
13 minutes ago, wONKEyeYEs said:
Buy Samsung.
which model
Assuming that you already have a HDD for mass storage, you can get a crucial MX300 275GB sata SSD which will improve windows boot times and game loading times as well. A normal sata SSD is enough for general purpose use whether its game loading times or windows booting, its enough for your needs, if your transfering large amounts of data, then NVMe is good for this in terms of read and write speeds. Whatever brand you choose to go with for an SSD, the performance will be identical across the board in terms of overall performance.
In terms of the brand of SSD, I'd recommend samsung, like an 850 evo, 250GB SSD, or in your use case, since you have a good budget to spend, 500GB, if you can get it for the right price.
Thanks for the reply! Can you tell which one is best overall performance 850 Evo 250 GB, Crucial MX300 275GB & 850 pro 256 GB?
SSD only help to boot window and game or also help me to open many chrome & browser tab or multitasking?
Just now, simu said:
Thanks for the reply! Can you tell which one is besy overall performance 850 evo 250 gb, crucial MX300 275GB & 850 pro 256 gb ?
As I mentioned, performance with sata SSDs, regardless of the brand, perform identically across the board in terms of performance. I'd recommend the samsung 850evo 256GB SSD, they are good value for money and are quite reliable. Fair enough if you want the extra storage, then go with MX300, but 256GB seems enough for your use case.
Yes, the performance increase with an SSD is noticeable when it comes to these tasks.
Thank you
Most popular would be samsung evo 850 ... I'm using it for few years now and never had any problems with it.
It can survive 75TB written data on it (250gb model), so that should be plenty even for (ab)users.
You can also cehck here to see performance between SSDs: http://ssd.userbenchmark.com/Compare/Samsung-850-Pro-256GB-vs-Group-/2385vs10
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
Can you tell me which one can provide better performance 850 Evo 250 gb or 850 pro 256?
You wont see a performance difference between the two and it isnt noticable from an everyday use stand point. The only difference between the two is the storage capacity, 250GB vs 256GB, unless you want the extra 6GB, then by all means get it, from a performance perspective, there isnt any difference when it comes to the storgage capacit that will affect performance of the SSD.
Samsung 960, but that one is M.2 and not sata.
WD My Cloud 4TB
