Chrome > Settings > Advanced > Reset > Click Reset.
This will reset chrome to it's factory default state.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
21 minutes ago, ImHyperstyle said:
You've probably got some adware....
here's the solution:
https://www.malwarebytes.com/adwcleaner/
then go to chrome > settings> manage start-up pages > and remove yeadesktop.com from the list and set to 'open the new tab page' or google.com
when i try to install it, it says "this program has been blocked for your protection"
Then you're gonna want to look up how to create a Kaspersky rescue disk, not sure if Malwarebytes also supports it. It's essentially a USB thumb drive with an OS and antivirus or Anti-Malware executables that will update their database and scan your computer.
"The only thing that matters right now is that you're here, and you're safe."
That's highly suspicious and backs up the malware theory imo.  Anything stopping you from installing malwarebytes - a program that gets rid of malware - is obviously up to no good.
what should i do, now i cant even download picture from google it sas blocked
Do you have another computer or a way to download a bootable media?  You'll want to get one to scan & clean and/or reinstall your main system.
- Moved to Programs, Apps and Websites -
 CHRISTIAN MEMBER
