For rough estimates, the ambient temperature difference is the same as full load temperature difference.
Desktop benching:
31 minutes ago, Shadowman said:
Obviously ambient temperature has a effect on the cpu/gpu temps, but how much roughly? Say for example a cpu any cpu at full load hit's 50c with the room temp at 20c  what would the same cpu  hit at full load but with the room temp at 26c?
if it is 50c at 20c ambient i assume it will be 56c at 26c ambient ... or it will still be 50c but the fans will spin a bit faster :D depends on how the fan curve is set.
any difference in ambient temps can be nullified by an increase in fan speed or CFM across the cooling surface.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
If everything stays the same, 56C.  I have precise water temperature control, 1 degree colder water = 1 degree colder CPU.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
