Hello,
I'm having a debate at work with a co-worker. He's building a server computer and all I know is that he chose an AMD Ryzen 16 core as the CPU. From my knowledge, you would want to run a different CPU designed for sever rooms and not gaming. Would that AMD Ryzen work or what would be recommended instead for use?
Thanks for any info. Sorry for the lack of computer knowledge. I really appreciate everyone's help.
Nick
https://linustechtips.com/topic/842145-suggestions-for-sever-computer-build/
So you have it backwards, but its not your fault, its marketing. The threadrippers, aren't meant to be "gaming" cpu's. They are built for things like servers, or creation based PC's. People just use them for gaming, and lump them in with the more gamer oriented CPU's, but honestly they perform worse in a lot of gaming situations. AMD just didn't stop people from viewing them that way, and marketed that you COULD use them for gaming, but that is not their primary purpose. Their purpose is to offer a better value option for cores and threads for those who need things like a server, or a pc for video editing, 3d modeling, etc.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
A CPU is a CPU is a CPU
Their target market might be different but they all roughly do the same thing. Sure you might pair them with different hardware but there isn't anything stopping you from using a server CPU for gaming or vice versa. Some CPUs are better at games because they are more optimized towards better single core performance but they can be used in server applications just fine, it's just the server application might not be able to run as effectively on a more limited amount of cores/threads. It mostly depends on the application, what it needs, and what environment it was designed to run in such as many slower cores or a couple very fast cores.
Edit:
Should have mentioned there are some features on a server grade CPU that aren't usually found in consumer grade CPUs but if the application(s) being used don't need those features then it's perfectly fine.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
You can use consumer hardware and call it a "server".  The difference between a Xeon and a Core CPU is whether or not it supports ECC.  I don't have any "must work 100% of the time" usage scenarios to justify having to use a server motherboard with a Xeon CPU and ECC memory.  I tried converting my storage server over to Xeon and it was a fucking nightmare when the new motherboard didn't really want to boot with the existing OS install.
Whether you want 8 cores or 16 cores depends on the workload.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
It's actually perfectly capable of doing so. It even supports ECC, for redundancy, as long as your board supports it. Xeons do have some features not shared with their consumer counterparts, but epyc and threadripper are actually quite similar in this regard.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
