jQuery get clock input to minutes and get between and display in input
Solved by leonfagan71,
2 hours ago, Joveice said:Hello, So I want to get the time between two times and display the total minutes in an input. How can I do this? I'm not a javascript guy.
This is not what I intend to use, but from there I know I can get it to work as I want it to.
<div class="form-group"> <label class="sr-only" for="displayTime">Tid</label> <div class="input-group mb-2 mr-sm-2 mb-sm-0"> <div class="input-group-addon"><i class="far fa-clock"></i></div> <input class="form-control" id="displayTime" disabled> <!-- display here --> </div> </div> <div class="row"> <div class="col"> <label class="sr-only" for="timeStart">Tid</label> <div class="input-group" id="clockStart" data-autoclose="true"> <span class="input-group-addon"> <i class="far fa-sign-in"></i> </span> <input class="form-control" id="timeStart" value="08:00"> <!-- start time --> </div> </div> <div class="col"> <label class="sr-only" for="timeEnd">Tid</label> <div class="input-group" id="clockEnd" data-autoclose="true"> <span class="input-group-addon"> <i class="far fa-sign-out"></i> </span> <input class="form-control" id="timeEnd" value="15:30"> <!-- end time --> </div> </div> </div>
