Charge and discharge cycles
Solved by Mira Yurizaki,
Every time you do a deep discharge on a lithium type battery, you lose a bit of capacity (among other factors but this is one of them). After 500 cycles, the capacity is going to be at a point where the battery is considered no longer useful. That doesn't mean it won't hold a charge, but it means more like it can only store 50% of what it could brand new or something like that.
I don't know what the real value is, but that's what it means.
