so ive connected my main monitor to my gpu,
and willing to connect my second monitor to my mobo, but the port wasnt working, so i asked for help and i got my answer by the help of some people from this forums.
but i cant seem to find the option in my chipset settings in bios to enable igpu or something of that sort..
motherboard: gigabyte ga ab-350 gaming 3
https://linustechtips.com/topic/838783-motherboard-problem/
Why don't you connect your second one to the GPU as well?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474787
It's because Ryzen series processors (like your Ryzen 5) don't have a built in GPU, so there wont be a way to get video out of those ports on your motherboard.
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474796
then why did gigabyte include an hdmi port in the first place..
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474799
btw i switched to ryzen 7 (if that makes a difference) forgot to edit my build here
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474801
Because of the A series APUs (A8, A10, etc.) which do have a (pretty decent) built in GPU.
The AM4 socket can hold Ryzen series CPU's, Athlon series CPU's (which are based on another architecture, not Zen) and also these APUs, so people like Gigabyte have to include these ports.
What I said applies to Ryzen 3, 5 and 7, so doesn't make a difference :)
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474805
3 minutes ago, Versti said:
there's only 1 hdmi port in it, and im out of money so cant buy a new dvi or a display cable.,.
Thats literally just $5 dude. Wtf
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474807
so i pretty much cant connect my second monitor to my pc unless i get an adapter for my gpu or a totally new cable, right?
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474815
AB350 Gaming 3 and Ryzen 7?
Oh boi.
Whatever.
As the others said, Ryzen has no iGPU, you need to use the one you use normally.
You can order the adapter from something to DVI on ebay for few bucks.
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474825
Well, yeah basically.
Also, most big stores make their money off their cables, which is why you can pay up to 40 USD for a DVI to HDMI cable. Take a look around (online) and just get the cheapest option for you.
DVI to HDMI is always decent, but it just kinda depends on what your display and videocard have in terms of input and outputs respectively.
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474831
Oh boi.
Whatever.
that would take around a month to arrive (not joking)
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474832
i guess ill get a vga to dvi, since its really only gonna be used for skype,discord,twitch chat etc.. and not gaming so vga should be good
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474837
Yeah, should be fine.
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474843
Keep in mind you're gonna need an ACTIVE adapter for your GPU. A cheap passive one will not work or even fit.
Image result for dvi-i
Those four pins on the right, around the flat part are for the analog signals (which is what VGA uses), which are not present on your GPU.
This is why I mentioned DVI to HDMI, usually the cheapest.
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474849
the 1050ti does not have a VGA output. the DVI connector it has is digital only.
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10474902
50 minutes ago, Versti said:
off to convincing parents (and yes i beg them for 5 bucks, dont judge, im a bankrupt machine)
Don't feel bad. My wife shelled out $140 for my RX 460, just to have to spend another $30 for the DVI-VGA cable for my monitor. #feelsbadman
https://linustechtips.com/topic/838783-motherboard-problem/#findComment-10475026
