I have a budget of $500 also for some if the parts it was cheaper to get them through Amazon because my wife and I both work at a Fulfillment Center so we get a discount on the website. Also I was able to save some cash by Ccarrying over my Rx 460. This build will be used for gaming and video editing. If you have any suggestions please let me know.
Newegg parts
Amd ryzen 5 1600+ ASRock ab350m board bundle ($271)
Vivo smart micro atx case ($34.99)
Open box silicon power 8gb ddr4 2400mhz ($60)
8gb flash drive to install windows 10 ($5.99)
Amazon
Toshiba 1tb hdd ($41.99)
Patriot torch 128b sdd ($51)
Thermaltake 500w psu (39.99)
The total before my %10 is $511.92 but it should be under $500 once it's added.
https://linustechtips.com/topic/837756-thoughts-on-my-current-build/
Newegg parts
Amazon
Looks pretty good to me, maybe might want to consider RAM with a higher speed tho.
My first concern would be the PSU, not knowing it's part number. May I suggest the Corsair CX550M?
You could also drop down to a Ryzen 5 1600 and maybe use any savings for a better kit of ram.
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
3 minutes ago, Swfcris said:
It's 7200rpm sorry should have mentioned that.
everything seems fine in that case, however id recommend getting an kingston / samsung ssd instead c:
aswell some branded ram ( dont take weird brand rams ),   g.skill / corsair / kingston recommended
check ur motherboard QVL list ( memory )  to see which brand is supported the best
Would this be the part number? (PS-SPD-0500NPCWUS-W) it had 4 1/2 stars on Amazon and it looked well reviewed.
No
no
no no
NOT THAT PSU
For the same price, on sale, you can get a CX450M, much better.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
I'm not really feeling it. I base my opinions on that Tier list I posted. If it's not in the top 3, I'd avoid it.
i dont wanna be a party pooper but i remember cheap corsair psu,s going in smoke due to failures , i wouldnt  recommend any corsair psu at all ( that is low end )
id say go for antec psu instead, or other a brand ( corsair psus are only known to be good on the high end range, the expensive ones )
corsair cx series have an history of catching fires on many models ( normally i dont even mention psus going on flames but those went insane before i remember that )
Sometimes it's just way too relying on electrical performance, so I would read reviews instead.
Top 3 for gaming PC, top 4-5 for office PC.
Full Specs
Helios EVO (Main):
Delta - Laptop
Nope. You cannot judge by brand. The Antec VP550 is much worse than the $40 Corsair CX450 (2017), so review EACH unit seperately.
Full Specs
Helios EVO (Main):
Delta - Laptop
google about the corsair cx series, they have a huge history of catching fires actually and extreme amount of failures ( also rated as poor power supplies for a long history )
corsair  cx series is the last ud wanna pick due to their poor history ^^
Corsair came out with a brand new CX and CXM series, and they are good, and better than the M12II, S12II, EVGA B3 and a lot of other units.
Full Specs
Helios EVO (Main):
Delta - Laptop
The ones with the green label, perhaps.  The grey label are good quality.
just warning about corsair cx series lmao
http://www.tomshardware.co.uk/answers/id-2883758/corsair-series-bad.html
The CX600 is available in green label only. Try finding a bad review for the CX550 (2017) or the CX450 (2017) or evan the CX550M.
Full Specs
Helios EVO (Main):
Delta - Laptop
like i said, a series known to have an issue that serious i wouldnt trust my components on there ^^, rather pay 10buck more
coilwhining ect also seems to be an issue on those psus
poor capacitors is somthing that shouldnt be taken lightly
They completely overhauled the series.
http://www.tomshardware.co.uk/corsair-cx650m-psu,review-33693.html
The new series is known to be a extremely good PSU, better than all the competitors, including the M12II and EVGA B3. You can tell because the label is grey (or it says 2015/2017)
also issue of green units
@STRMfrmXMN
@jonnyGURU
Full Specs
Helios EVO (Main):
Delta - Laptop
http://www.tomshardware.co.uk/answers/id-3287170/corsair-cx650m-permanently-dies-minutes.html
? first thing i check ._.
The CX from pre-2016 are vastly different. You're getting a totally different unit. The old CX series got a lot of hate for "blowing up" when, in reality, it would just restart itself if it got too hot (which is what it's supposed to do, mind you). It did this as a lower temperature than preferred but it's still nowhere near the pile of explosions waiting to happen that many make it out to be. The CX550 is a very good unit.
Random person on the internet had a problem with hardware. Look up "Gigabyte SOC Champion RAM not working." I haven't even Googled to see if this is a problem someone had with one of the most expensive motherboards in existence, but I'm sure somebody had to have an issue with it.
4 minutes ago, Valkyrie Lenneth said:
Every unit will have some problems, even with the AX1500i. Look at these measurements of electrical performance, and it competes with units like the Hydro G 650.
59c487d2cbe5b_ScreenShot2017-09-21at8_45_51PM.png.5ac900d0eb1792de3402cc062913cf6f.png
59c487d44f3fe_ScreenShot2017-09-21at8_46_23PM.png.ecaa57e0cf76579b3f9d08dc4d54bca3.png
Full Specs
Helios EVO (Main):
Delta - Laptop
It's not a rework, it's a completely different unit. Completely different design.
Look at the inside:
Edited by wkdpaul
Cleaned up
Full Specs
Helios EVO (Main):
Delta - Laptop
