Does anyone know why this doesn't work
strat_map = {
  '1': lambda: print('One'),
  '2': lambda: print('Two')
strat_map['1']
strat_map['2']
but this does
strat_map = {
  '1': lambda a: print('One'),
  '2': lambda a: print('Two')
strat_map['1']('')
strat_map['2']('')
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/835869-python-dics-and-lambda/
The first one just returns a function object, the second one actually calls that function object.
But since you don't use the arguments at all you should just do
strat_map = {
strat_map['1']()
strat_map['2']()
1474412270.2748842
https://linustechtips.com/topic/835869-python-dics-and-lambda/#findComment-10444056
