I hereby challenge LTT to do a build only using the fans of the same kind of that one i found today in my basement. funny story this fan i found is "made in w-germany", before 1990, and i wondered if they were still produced. And they still get produced! :Dhttp://www.ebmpapst.com/de/products/compact-fans/axial-compact-fans/axial_compact_fans_detail.php?pID=53850
you probably have to set the site to english.
the crazy thing about these fans is: the are 120 mm fans and/but they have to be powered directly from the wall with 230V ( the common power from the wall here in germany) im kinda backfiring on myself because i complained about not enough serious tech vids on the main channel only two days back but oi hope to see a video using these fans :D The case will probably just bump around from the vibration of these fans, but hey, they are wall powered fans.  Please, just make it happen.
am hungry
https://linustechtips.com/topic/832170-kill-dat-power-bill1/
13 minutes ago, Hiitchy said:
What's the RPM like on it? I know they did a video on an 11K RPM fan but I'd imagine this were similar if not faster.
http://www.ebmpapst.com/media/content/info-center/downloads_10/catalogs/compactfansen2011/compactfanssingle2011/AC_axial_fans_2016_01_EN.pdf
skip to page nine im not sure which one excatly i have herte but should be the 4650N
they arent faster by any means, but they have a minimal runtime 37500 hours at 40°C and they push 160m³ of air in an hour xD
am hungry
https://linustechtips.com/topic/832170-kill-dat-power-bill1/#findComment-10405725
Eeeh...? How would connecting fans directly to wall do anything to power bill? I would argue (and google verifies) that those use more power than normal 12V PC fan. Even if it would be super-charged like Noctua iPPC.
Product sheet for these say 9-12W where iPPC uses only 3.8W.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/832170-kill-dat-power-bill1/#findComment-10407977
youre right, but seeing fans directly powered from the wall suggests they would drain a lot of power and 12W is much in comparison to the 3.8W of the Noctuas. they might not drain enough power to make a noticeable difference on a power bill, but still wall powerded fans are funny and uncommon. i mean this post was made in hope llt would use these to cool a case, so...still hoping here
am hungry
https://linustechtips.com/topic/832170-kill-dat-power-bill1/#findComment-10408482
not as uncommon as you may think.
they are very common in all sorts of industrial machinery, whole-building air conditioning systems, equippment for stage lighting and such
https://linustechtips.com/topic/832170-kill-dat-power-bill1/#findComment-10408710
