Need a little help if possible
By
dv8t
in Power Supplies
in Power Supplies
Solved by CableMod,
@dv8t if you're just looking to replace the cables showing, check out our ModMesh sleeving option and the White as Blake has mentioned. It'll reflect the LED lighting nicely so your cables will take on the colors. Use "PSU Cables" to purchase these individually from our configurator page.
Serendipity1344 ·
Posted in Graphics Cards2 -
1
1
5
1
toxic_worper ·
12
1
voltigeurramon ·
Posted in Troubleshooting2 -
2
